| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 584 | For those who follow the BillyBob logs, a new Work-in-Progress log entry "A little of this, a little of that" has been posted. As the title implies, it's a hodge podge of little things and, in the middle of it, BillyBob and I take off on the Hutchinson roadtrip (but you already know that part of it). A little of this, a little of that | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Its always good to read your logs on BillyBob. Thanks. You seem to have a wide range of tastes in beer too. Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Jul 2000 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 584 | Yes, Jeff. I'm a "commonsewer" of fine brews.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Larry,Oddly enough I ran into the same valve cover SS bolt situation you have using Langdon's kit too.I added SS flat washers that allowed to me to gently cinch up the bolt without overtightening. Hasn't leaked yet.
Drew
