| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42410 03/14/2004 2:53 AM | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | Hello everybody, I am planning on putting a saginaw 4 speed behind my 235 useing the Patricks tork tube conversion.I will also be changeing the ring and pinion to 3.55:1.Just looking for any feedback from anybody who has done this,how did it go?How do you like it? Aaron | | |
#42411 03/14/2004 3:03 PM | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I just completed a conversion on my 51,3100, with a 235,I used patricks hurst shifter with the saginaw, I opted to use a ten bolt rear from a blazer,I paid a hundred for the rear and eighty five for the spring mounting kit, used a drive shaft from a camaro had it reworked for 150,00, rear ratio is 3:23,I can now drive at seventy with more to go,You lose a little on the low end. Wth the patricks kit you will only gain 10 mph,and still have the torque tube. I also changed to duel master cylender while I was at it.Good luck.......... | | |
#42412 03/14/2004 3:41 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I just finished installing Patrick's 3:55 into my enclosed driveline not touching the tranny. It took me more time than expected because I tinkered with other items while I had the backend torn apart such as new SS brake lines and new master cylinder, etc. Setting the backlash was probably the most intense part of the project but all is done and I'm now traveling yes around 10 mph faster. Even with this minimal amout of speed increase, I'm always thinking about do I have the brakes to stop fast?
Traveling at 70+? I'd change to more modern brake such as discs.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#42413 03/14/2004 9:11 PM | Joined: Nov 2003 Posts: 18 Member | | Member Joined: Nov 2003 Posts: 18 | The cost of Patricks saginaw kit and the rear gears is just too much time and money for a 10mph gain. When you have it all done the rearend in your truck with a torque tube it is miss aligned by allmost 1 inch forward stock from the factory with no way to fix it. Cheaper and better way is like others have said. Camaro rear for five lug or 80s 4x4 chev full size rear with six lug. I put the gears in my 48 and with new bearing and labor it was more than my 46 with a 5 speed and a camaro rear. | | |
#42414 03/15/2004 5:24 PM | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | I also did the Saginaw swap on a 55 1st series with the open driveline. It was a pretty straight forward swap. The only thing to add to the previous posts is that if you also add a dual master cyl. conversion look for clearance issues. There is only about an inch of clearance between the shifter and the master cylinder for the brake line. Takes a pretty sharp bend in the line.
Steve 55 1st Series 3/4 ton
#42415 03/16/2004 5:24 AM | Joined: Aug 2001 Posts: 44 New Guy | | New Guy Joined: Aug 2001 Posts: 44 | Picking out a open drive line rear end with the ratio that you want, and then re-building it will cost about the same as Patricks ring/pinion for the closed driveline. Spring perches can be bought at Jegs for about $20. For those of you thinking about a F*** 9 inch, you can get a perfect fit for the E-brake hook up from Yogi's. Don't forget to set the pinion angle. Saginaw 4SP can be found for about $150. You could fabricate the shifter from a old truck 4 on the floor to save a few bucks. The special from Patricks looks and works well and as mentioned previously, there IS a space problem if a dual mount MC is used. Never tried to bend tubing that tightly before, but it does work - use a box end wrench to bend.
41 Chev 2dr coupe 51 3100 w/a 261 11 Camaro RS ragtop
