4 members (Gdads51, JoergK., cmayna, MNSmith), 89 guests, and 4 robots.
Topics128,181
Posts1,057,150
Members48,464
I have a 65 C-10 with 3 on the tree. The original transmission has been replaced with a Saginaw 3 speed. I want to replace that one with a saginaw 4 speed on the floor. Any advice on the conversion? The driveshaft has already been shortened, but I understand that the bench seat may be a problem. If so what bench seats will fit?
what's your purpose in switching to a 4 speed, do you need a granny gear? only problem with a bench seat [any one] may be that you'll have to custom bend a shift arm
I have a 65 C20, the previous owner replaced a 3 speed with a 4 speed. No issues with the seat, but the top of the transmission comes up through the floor. He did a hatchet job though. There were two different floors for those years: low hump for the 3-on-the-tree, high hump for the 4 speed.
To old to change, to young to quit.
With the Saginaw, most shift linkages available put the shifter too far back for truck use, which makes it interfere with the seat. There's really only a few choices on making one work, 1-cut a notch in the bench seat for clearance, 2 swap to bucket seats, 3 the custom bent shifter that red58 mentioned. There is a shifter from Patricks that clears the seat, but it is made for '47-'59s, I don't know if it will work with a '60-'66 body.
If you're looking for either a granny gear or a higher road speed, a 4 speed will not help. If you want the lower first gear, you'll want the SM420 4 speed, along with the different trans cover GrimGreaser mentions. If looking for better road speed, you should take a look at a T5 5 speed, which has an overdrive gear. That trans also has a provision for placing the shifter close to the same location as the SM420, so it will clear the seat. That conversion has been covered extensively, doing a search on this site will give you all the info you need.
Bill Burmeister
The 3-speed just doesn't have the correct gear ratio...either too high rpm for second or too low rpm for 3rd. I though the 4 speed would make the truck more comfortable to drive around town. I'm not looking for highway driving...only have the 230 engine.
Thanks red58
Thanks LONGBOX55, I'll research those transmissions. The 5-speed looks appealing. Will it bolt up to the housing on a 230 or is a conversion required? I was trying to avoid multiple conversions and understood that the Saginaw transmissions are the same length. The driveshaft has already been modified for the 3-speed.
