| | | Forums66 Topics128,284 Posts1,058,525 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 25 New Guy | | New Guy Joined: May 2005 Posts: 25 | I have a 46 chevy one ton truck. Stock rebuilt 54 Chevy 235 with rebuilt Rochester carburetor. Guessing that rear end is low-mid 3:00's-changed out before me.
Running a 5 speed overdrive trans from a 1954 REO truck. Over drive ratio is approximately .8/1. Truck will run 55-60? (no speedo gear on trans) comfortably on the interstate at 2500-2800 rpm.
Carb has been rebuilt several times. Orig carb had 'rochester sticking float blues'. Changed carb from my 235 spare motor.
Truck runs well. Judging by plugs, engine is running consistently rich. Also, base of carb is generally wet. (I have a Carter YF carb, but the linkage setup is completely reversed from the Rochester and I can't figure how to set up).
Is there a more modern carburetor from a later Chevy engine which would bolt up and provide better service and mileage? If Carter YF is ticket, do you have a source for the proper throttle linkage.
Truck is weekly driver, used for material hauling from Winston-Salem, North Carolina to Galax, Virginia. Most miles are highway miles.
Thanks for your help. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Are you running the right gasket in the base to allow the power valve to see manifold vacuum?
Also, what is your manifold vacuum running down the road? You might have low enough vacuum that the power valve stays open and runs rich.
With 3.0somethng gears and overdrive I would expect you to be more in the 1800 rpm range at 55 mph unless your tires are really small.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2002 Posts: 2,785 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,785 | Several threads on this forum concerning the power valve, which as mentioned by 4onthefloor, could well be the problem. Wrong gasket or body warpage can cause power valve problems.
Carter built LOTS of different YF carbs. There is another thread on this forum which lists the YF's which are applicable to Chevrolet engines.
Stromberg and Zenith are other options, and from a quality standpoint, even better than the YF; but the correct ones tend to be pricey.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
