7 members (MickeyP, David Bush, kades51, Gdads51, cmayna, Donf, 3800GUY), 90 guests, and 1 robot.
Topics128,049
Posts1,055,702
#423577 06/16/2008 2:05 AM
I have a gas mask from an NBC suit from work. The mask is good for CS, CN and other biological stuff. The question is; is this good enough for painting fumes or do I need something better?
Bruce
My Trucks
Stuff I Collect
I would not take the chance
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
Apprentice
Apprentice
i agree with 50adrod spend the money get one for paint you dont want to mess ur lungs up make sure they are the element type and not for dust the ones for dust dont work for paint and good luck
Back in the day it wasn't uncommon to paint wearing only a particle mask, but the way paints today smell I'm willing to wager that anyone who can breath those fumes without passing out could probably breath under water.
It's inconceivable to even consider painting without the proper respirator.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Ex Hall Monitor
Ex Hall Monitor
I'm not sure what an NBC suit is but if your mask is approved for VOCs (I think that stands for Volatile Organic Compounds) it should be OK for painting. Back in the day we often just used dust masks if anything at all. I can't tell you how many technicolor lung cookies I blew over the years. As I got older and smarter I started wearing proper gear. I'm surprised I still have lungs left. grin
Tiny #423775 06/16/2008 5:00 PM
Ive been using a disposable mask, good for 40 hours outside the bag, from my local auto paint supplier. Made by Gershon, cost abou $14 bucks. Seen some from 3M at NAPA as well. Well worth the price for safety.
Mike
Tiny #423807 06/16/2008 6:55 PM
The NBC suit I was issued for my job stands for Nuclear, Biological, Chemical. It's good for CN and CS gasses plus biological contanimants. I would think it would be good for paint fumes? Just hoping somebody smarted than me might know.
Bruce
My Trucks
Stuff I Collect
I use a 3M dual cartridge respirator, organic vapor/p95 assembly that cost between $15 & $20 depending on where you get it from. It also is good for 40 hours of use. I would not even consider painting todays paints without this as a minimum of protection.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
Ex Hall Monitor
Ex Hall Monitor
Bruce
I imagine that'll probably do the job. Can you say "overkill". grin
Tiny #423903 06/17/2008 1:40 AM
Bruce
You want overkill, THIS IS OVERKILL.
Bruce,
This response is based on over 25 years working in the environmental remediation field dealing with a wide range of hazardous materials. The answer to your question is no. It is not rated for paints, vapors or fumes.
CN and CS are two types of Tear Gas. Both are mist based irritants. Neither of which contain VOC based vapors or fumes. And, neither of which are neurotoxins. Here is a good description of both: http://www.safetyenforcement.com/csteargasfaq.html
Biologicals are particulates and are removed by HEPA filtration.
Many of the automotive paints that are out on the market contain VOCs that either require a respirator cartridge that is rated for paints containing activated carbon or a positive pressure fresh air supplied respirator.
Your tear gas approved respirator is not rated for toluene, xylene, benzene, isocyanate, lacquer thinner or any other volatile compound found in most automotive paints.
My suggestion is to use the right tools for the job. Get a respirator that is rated for the paint you are using. Leave the NBC suit and respirator at work
1949 "Heinz 57"
Thanks Dave, This is exactly what I needed to know. I'm not going to take chances with my health. Just thought if it would work I could use it instead of buying another mask.
Bruce
My Trucks
Stuff I Collect
Ex Hall Monitor
Ex Hall Monitor
Thanks for the info. Dave.
I was an NBC NCO in the military. The masks we use are mainly for particulates. They don't stop fumes, which is probably the most dangerous part of painting. Your mask will probably take the spray out of the air for you, but it should clog the filter(s) pretty quickly.
Your best, and cheapest, bet for spray painting is an inexpensive, throw-away particulate mask. (You can get 12 packs from 3-M for a few dollars.) DON'T WORK IN A CONFINED SPACE WITH JUST A PARTICULATE MASK. You'll either get high, or dead eventually. Best solution is a filtered, pressurized suit, or at least the helmet.
Trust me. A pressurized helmet is not overkill. Check some local paint shops.
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
Tanker wearing nods, How did you get that home...they took mine back to arms room.
Brad
Well, one of my additional duties was NBC NCO, but I didn't try to get my tanker's mask home. That would be ideal with the canister mounted in the center of your back and a connector for an outside air source. Especially since the M-17 was so clumsy.
The best ones I've found lately, other than the throwaways, are Israeli surplus. Tried the Russian model and they s<>k. The Israeli models are cheap, new filters are readily available, they have a lot better vision, and are a lot more comfortable.
But they still don't protect you against fumes. Best bet for that is over-pressure, just like in a tank.
