| | | Forums66 Topics128,193 Posts1,057,249 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | Is there enough room to replace the manifold gasket without completely removing the manifolds from the engine compartment. I was thinking that if I could get the manifold off the head studs on each end that I could remove the old gasket and replace the new one by just letting the manifold (with carb off) "rest" on the exhaust system and avoid pulling the whole thing out. Anybody tried this??? My engine is stock 216 in a 47 1/2 ton Chevy.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | mazzer,
I think you can do it that way. If the header pipe is strong enough to support the whole assembly, yet flexible enough to allow you to swing it back out of the way a bit, then you have it made.
Keep in mind the difference in doing it that way and removing it completely is only two bolts! Taking it all the way off would allow you to easily clean up the gasket surfaces....real important.
Don't forget there are three alignment rings that the new gasket will have to be slipped over. If I remember correctly, that intake/exhaust gasket isn't one piece either.
I think very little is to be gained by leaving it dangling to do this chore....but then again, I'm not the one doing it!
Stuart | | |
