| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 66 | what is the best way to go about adding tranny fluid? I have a 3 speed manual on a 54 with a 235. There is a drain plug on the bottom and it looks like a level indication plug on the side. Is that where I fill it at? If i have a blown rear seal will i be able to tell? Will there be oil in the tranny fluid? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, fill the transmission through the side.
If the engine rear seal is leaking, you will see fluid behind the engine, usually dripping out from the pan at the bottom of the clutch housing.
Some might say that if you are not leaking any fluid near the rear of the engine, you might be out of fluid.
Tim | | |
