| | | Forums66 Topics128,042 Posts1,055,601 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | Can the gmc 302 fit the chev 3 speed? This is from a old army truck about 60s vintage. is it worth the bother and are they worth much. I also found a 261 that hasn't run in 20 years with about 20 thousand miles, might be seized from sitting.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | A GMC 302 is a highly regarded engine by inline enthusiasts.Not sure about what Chevy parts match up easily,but there are performance parts for this motor available. A 261 is a good motor too,although it sounds like you would have some serious rebuilding to do.
Drew
| | | | | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | I would snag both of them as they are both becoming hard to locate. The 302 is a very good engine and I am sure you could shoe horn it into you Chevy! I think some of the guys over at Inliners International have already done this.
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A gmc is a few incheslonger than a chev but that can easily be over come and has been done many times. You will need a civilian oil pan, Carb, ignition and generator. The military ran 24 volt. Also most of them ran automatics and had a different bell housing. There is a boss on the block that has to be ground off to accept a civilian starter and the military blocks do not have a place for a fuel pump so you must use an electric fuel pump. The best is to have a donor engine for all the parts you need. I have leaned toward GMC for 50 years, but there is nothing wrong with a 261. It's a lot easier conversion. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | ".....the military blocks do not have a place for a fuel pump so you must use an electric fuel pump." To clarify this, military blocks do have a "place" for a mechanical fuel pump. There are just no holes there. Using a fuel pump gasket for a template, many people have put the holes in their engines. For a very detailed list of what needs to be done to a military 302, see http://www.oldgmctrucks.comTo answer your original question, your bellhousing will fit the 302 block. You'll need a GMC flywheel. Yes it is worth the bother. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I've got a '55 302 I'm getting ready to put in my truck. You will also need a new front mount plate if it has the "u" mount. The one from a 216-235-261 will fit but you have to pull the cam to install it. Earlier blocks have the standard front mount.
The nice thing about the 302 swap is that its a torque monster, it weighs about the same as the 235, has a 2bbl manifold already, and has a high mounted, short water pump.
They can be pretty expensive to rebuild if you are going for performance, though.
