1 members (Hotrod Lincoln), 153 guests, and 6 robots.
Topics128,268
Posts1,058,379
Members48,485
#422608 06/13/2008 2:18 AM
The previous owner assembled the steering column and I put the engine and trans in place.
The trans shift fine when pushing on the linkage.
When moving the column shifter nothing happens. I can get it to go into R and 2nd sometime but will not come back out.
I checked the clamps on the shaft(under the dash) and they both seem to be lined up with the bolt though the notches and the bolts install in the top of the clamp.
The shift lever lifts the shaft up and down but does not seem to engage in the box in the engine compartment. There is grease and dirt on the screws on the box and it looks like it has never been apart.
What might be out of place that would make the shifter not work?
Is there something simple in the little box that can come dis-engaged?
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
that lil box is usually where all the shifting problems happen - there's a pawl that catches slots - the pawl and slots get worn and the movement gets trapped between gears - you need to get that box right before anything else [open it up and clean it and regrease, make sure the spring is there], then the rod length is adjusted by threading the top knuckle up or down ... and make sure that coupling is really tight, even when the bolts are in, the rod may twist in the coupling
jdl Offline
Take the cover off of the box. There are two C shaped couplings in there with a tang in the middle. Make sure that when the truck is in neutral that the C shaped couplings are lined up.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Yep easy fix the tang was not in the middle.
smooth shifting!
Hook up the gas tank and install the drive shaft and it will yard drive!
THANKS AGAIN!!
Regards,
Lindsay
