2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
So...my good buddy has the origional 283 that came out of his 1957 Chevy pickup. I have a 1961 1/2 ton 2wd with a 235. Is this feasible? I am looking to do the swap in the garage over the coming winter.
Motor mounts? Steering clearnace? Your thoughts and knowledge would be greatly appreciated!!!
Turbo!!??
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
the 61 would have had a 283 as an optional engine, you just have to get original mounts to install it, shouldn't require any modifications .... it should all be shown in the factory assembly manual
Just be aware that nothing from the 235 is compatable with the
V-8. Presuming that you have a stick shift, it has a hydraulic clutch slave cylinder. If this is the case you will need a V-8 belhousing (60-62) with the hydraulic set up.
Fred
Thanks guys...it gets here on monday...I can't wait!!!
My Machine
