6 members (46 Texaco, Shade Baby, BarryP, Oswald, Robert Crandall, dt235sd), 92 guests, and 2 robots.
Topics128,162
Posts1,056,910
Members48,458
#421541 06/09/2008 7:19 PM
I had engine sitting on the garage floor for a couple of weeks..I've since put it in the truck(55)and notice it now leaks a bit..I can tighten it more and goop it but was wondering what the original gasket material was.
tx
Keith
A plastic/nylon or copper washer might help.
You should be able to get the correct gasket from the flaps, especially if they carry Dorman. I think I have a catalog around here with the correct # for a 235, it might be at the shop. I'll see if I can find it if you want the gasket and/or plug #s.
BTW, you may want to replace the plug at the same time, the threads may be worn/streatched from overtightening by either a po or quick lube place trying to stop a leak rather than replacing the gasket. that can also cause a leak like what you have.
Bill Burmeister
really-never thought about replacing the plug-but I might as well ...I'm relacing everything else!
Ya if you show a listing in the book let me know..
Thanks Bill
Seems that the Dorman catalog is in my toolbox at the shop, however, I do have Service Supply (another brand name for Dorman) catalog handy. The part number for that brand is 365202. Make sure you ask for one with the gasket, sometimes they don't come with one.
Bill Burmeister
Thanks Bud-
Keith
For future reference, Dorman has online catalogs.
DORMAN Products Online Catalogs
Joe
'67 Chevy C20 fleetside, 250 inline, 3 on tree, heavy duty clutch and brakes, heater, steel bed floor
"Tighten until the stud snaps, then back off half a turn."
