Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (Peggy M, homer52, TUTS 59, JW51), 570 guests, and 1 robot.
Topics126,776
Posts1,039,274
Members48,100
Most Online2,175
Jul 21st, 2025
#421084 06/08/2008 6:56 AM
With gas prices going sky high, I was wondering what my 1954 3100 inline 6, single barrel Rochester, 4 speed should get when it's ready to drive? I would like to hear what some of you are getting.
There are a lot of variables to determine how you'll do. Somewhere between 8 and 18 mpg would be my guess.
If it runs poorly and isn't tuned well you'll get rotten mileage.
If its in good condition, tuned for maximum efficency and you drive it carefully you could get 18.
My '55 1st GMC Suburban with a GMC 270 averages 14 driving a mixed highway/surface street commute.
A whole lot depends on final drive ratio and tire tread height. If you have the original 4.10 and current 15" rubber it will be appalling because your engine will be screaming as soon as it gets on a highway. Light to light it will be fine.
If, on the other hand, you have a higher (lower numeric) ratio such as a 3.55 or an overdrive transmission, or 7.00 x 16" tires, or a combination of the above, your fuel economy could easily top 20 mpg.
1951 3800
-hotshoe
With the original 1/2 ton 3.90 1954 rear-end and ~30" diameter tires, I got 18 mpg going to Baltimore and back two years ago.
I use to regularly average 15 mpg and rarely went below 12 mpg.
While everyone is being conscience about how they drive, Im driving the old truck more and more.
If Im going to be bent over every time I decide to fill up, Im darn well gonna enjoy it!
My 1953 Chevrolet
1947.1 Gallery
right now the best the 52 wil do is around 18 if I keep myself dissaplined and run it right, now when the the erge to FLOG it an kick the 4 barrell in an run her up to 80 superceedes common sence...well DO THE MATH...lol...but runnin to work daily it does suprisingly well until my BAD half takes over an wants too hear the pipes,pass a few new cars or just burn some tire.
Tim
1952 Chevy Shortbed
Photos in Photobucket
As hotshoe36 posted,your final drive means a whole lot.If your gonna run with 3:90 or 4;11 gears in the rear and a straight 4 speed trans. you wioll not get good mileage. Change the reaend out to 3:08 gears, or put in an overdrive trans. and your mileage will improve.In my 55 I am running a 350 built engine,coupled to a 700R4 trans. and 3:90 rear and getting 20 MPG.The 700R4 overdrive is turning the rear at about .78 to 1 ratio. Whereas with a straight 3 or 4speed the ratio is to 1.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.037s Queries: 14 (0.033s) Memory: 0.6232 MB (Peak: 0.6945 MB) Data Comp: Zlib Server Time: 2025-09-22 16:11:29 UTC
Valid HTML 5 and Valid CSS
