4 members (Robert Crandall, mick53, Danielbolt, 1 invisible), 165 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
I am having trouble finding the right upper ball joints for my 63 C-10. I ordered a set from Autozone and the base was bigger than my originals and would not fit. I had them get some 62's in to see if mine was a end of the year (62) part or something, but had the same result, the base was just about 1/8", 3/16 too large. Anyone else had this problem before??? Also, what are you guys using for the rubber bushings on the control arm shafts? I may be able to find some rubber hose for the small bushing on the upper arm, but need a good idea for the lower.
Thanks, Rick
go to "KANTER AUTO PARTS".
do it once,do it right.
