4 members (baldeagle, walter74, kades51, 1955 1 Series), 70 guests, and 3 robots.
Topics128,014
Posts1,055,328
Members48,419
#42077 05/23/2003 3:48 AM
I'm trying to figure out what type of engine I have. I've tried every list of engine casting numbers I can find (starting with Inliners), but I can't find this one. The number cast on the cylinder head (above the 2 / 3 cylinder exhaust port) is 3835918. The closest thing that I can find is 3835917 which is for a 54-55 235. By the way its a '53 3100.
Is there any way to tie an engine serial number to a vin number? Or is it possible to identify the engine by the serial number? The number stamped on the flange by the distributor is 0507735 F54XA.
#42078 05/23/2003 4:53 AM
I'd say those numbers look like 54 235, specially the "F54XA", which I'm sure someone here can translate - what it's in 50 years later doesn't say much about what it is - depending on where the truck was first sold, the VIN on the title may be the engine number rather than the body serial# on the door pillar tag
#42079 05/23/2003 1:19 PM
Thanks for the reply. I mainly wanted to translate the engine serial number to the VIN out of curiosity. I also thought that might help nail down the year of the engine.
I didn't realize it before, but you're right. That "54" in the middle of "F54XA" does stand out. Maybe that's why I've been having trouble getting parts for a '53 engine to fit just right.
The truck was originally sold in Mississippi or Alabama (I forget which now, but I think it was Mississippi). Fortunately, it was titled under the VIN so I don't have to worry about the different engine number.
#42080 05/23/2003 2:00 PM
F = Flint Engine Plant
54 = 1954
X = Thriftmaster "235"
A = used in 3600 series
0507735 = engine sequence number (started at 0001001)
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#42081 05/23/2003 3:49 PM
53,
My 1953 was bought with a 1939 216 ci engine in it. Cant believe that it still ran. I have a 1954 235 ready to put in her as soon as the time presents itself. 1953 was the last year Chev used the 216 Babbit Bearing engine in the pickups. 1954 started with the 235.
1953 Chevy 3100
The Green Truck
