1 members (TexasA&M48Truck), 67 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
#42046 05/17/2002 3:13 PM
I searched the stovebolt archives for 228 swaps. The discussions were mostly for AD trucks. Does anyone know if a 40 GMC 228 will drop in a 38 chev without serious modification to the frame? What I gathered from previous postings was the front engine mount and exhaust manifold are different. My "extra" 38 has a long stuck engine and a running 228 may land on my doorstep.
One who knows that enough is enough will always have enough. Lao Tzu
The main problems you will have are the clearance at the radiator as the GMC engine is longer.The front engine mount is located an inch+ further forward.
.You may solve the radiator clearance problem if you use the GMC radiator as it is mounted a little firther forward than the chevy.(side brackets are angled differently on the two trucks.
Now you're talking! Get a REAL engine in that Chevy.
You will likely have to run a short shaft water pump and maybe even more to squeeze the longer 228 into the 216 space.
