2 members (1955 1 Series, Ponchogl), 329 guests, and 3 robots.
Topics128,163
Posts1,057,044
Members48,463
I installed the engine and trans in the 58 today and tried to hot wire the starter to roll over the engine.
I put the positive lead on the starter and I am wondering now what do I hook up to get the starter to roll over.
Pushing the foot pedal does not do anything.
Does the small screw under the 12 positive lug nut need 12v to activate the starter??
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
see here - the ignition resistor bypass goes to the coil ... and of course you need a good ground from the batt to the engine
when you push the pedal, the lever moves back and depresses the button that makes the electrical connection inside that little box on top .... it also pushes the starter gear to mesh with the flywheel
58GMCanuck,
If this is a stomp type starter, a "foot starter", it is leg power that drive the bendix in and completes the circuit electrically. If you have a good battery connected to the large lug on top of the starter switch AND the negative cable attached to the engine/frame, the starter should turn over when you depress it far enough. Is this what you did?
Stuart
If the battery is grounded to the frame you also need a ground strap from frame to engine, usually connected under a bolt for the foot start linkage on the right side of the bell housing, and to the frame.
•1952 Chevrolet 3800 pickup
---All pictures---
THANKS
I think my problem is the copper lug is quite worn in side the little box and the lever would not depress the copper contact all the way.
Can I buy just the little box on the top of the starter?
I got it started with a regular starter that came with the truck,
Regards,
Lindsay
Lindsay,
Jim Carter Trucks has a replacement starter switch. It's # EL112.
Stuart
jdl Offline
You can also go to NAPA, and get it right now. I just went in and asked for a starter switch and 20 some dollars later have a new switch on the starter.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
I thought GMC had already discontinued the foot starter by 1958. If not, does anybody know what year they changed? It seems like Chevy still had it after GMC changed over. Anybody?
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Chevy had it until the end of 59, I think GMC did as well, both for six cyl only
I have a Canadian built GMC which is a chevy drivetrain 235 3 speed.
Our Pontiacs ran sbc many years as well.
I had a 64 Pontiac Acadian Wagon (nova) with a 283 factory , still miss that car.
Regards,
Lindsay
