5 members (Gdads51, klhansen, Otto Skorzeny, Steelonsteel, 1 invisible), 76 guests, and 1 robot.
Topics128,051
Posts1,055,710
#419165 06/02/2008 7:13 PM
I did a search and came up empty handed.
I just bought a rear end from Jimbo, nice guy. Anyhow, is there any way I can identify what year its is? Or if it is a first edition or second edition (saw that question in a parts catalog). From what I can tell, there is no tag on the rear end. It is from 1955 to 1959 per Jimbo, I was just hoping to get the precise year and gear ratio.
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
You can pull the back cover off and look for a number stamped on the ring and pinion gears. That will let you identify what gear ratio is inside.
My 1953 Chevrolet
1947.1 Gallery
if it came out of a 55-59, it won't matter what year, they're all the same - and the standard was a 3.90 ratio, very unusual to find any other .... real easy to find the ratio before you install it - you should open it up to clean, check the gears and replace the gaskets anyway, just count the teeth
