2 members (Waveski, Steveoreno),
80
Mod | | | Forums66 Topics128,184 Posts1,057,267 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 10 Member | | Member Joined: Apr 2003 Posts: 10 | I've read posts here about double 00 cable grounding directly to the starter for better cranking power. NG I just did the double 00 cable from the negative to the starter still the same. Question can you use two 6 volt batteries hooked up in parallel or in series to get more amps. leaving the volts the same?
Thank in advance. | | |
#4188 10/05/2003 10:38 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | You told us all about your new negative cable..What shape and size is your positive cable ?
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#4189 10/05/2003 11:04 PM | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Hey guys, I did the cable switch, on my '53 COE yesterday. Made a world of difference. Also installed a fresh 6 volt battery. You can't use 2 gage battery cables from your local Pep Boys, Autozone, etc., it's not as big as 2/0 gage Industrial cable. I purchased about 20 ft. of "Belden Battery Cable", from one of the local Big Truck shops. I plan to redo the battery cables on three of my COE's | | | | | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | Measure the voltage drop in each cable. For the hot side, use a meter directly from the PLUS post to the post on the starter.
For the "ground" side, scratch the paint off a bit of the actual starter itself, and measure from there to the MINUS post.
LBNL, measure + to - post on the battery while cranking.
You're gonna need a helper for all this.
Then compare. Whichever side of the wiring has the larger voltage drop is where the problem is.
Cheers! George | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | All very good points on the cables and grounding however no one asked you if you had the points set properly and the timing properly set. Make sure you are getting proper voltage to the coil and to the distributor as well. One more thing,, how good is the battery you have?
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | And what shape is the starter in? Is the switch (on top of the starter) burnt to a crisp? Does it need new brushes?
If the engine is turning over slowly, check these items: 1. Charging system 2. Battery 3. Timing and ignition 4. Voltage drop, both for connection loss, and how much does voltage drop when starter engages. 5. Connections 6. Starter
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Fred T makes a good point about the starter condition.50 year old parts or suspect starter "rebuilds" may cause problems. My 45 2 ton with a later 235 turns over just fine on 6 volts even though it has cheapo 2 guage cables,must be the starter, huh? | | |
