| | | Forums66 Topics128,163 Posts1,056,918 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 2 New Guy | | New Guy Joined: Sep 2004 Posts: 2 | The rear end in my 56 GMC "Frances" short stepside is going bad. I want to swap a late model rear with higher gears because I am on the highway 5 days a week. The old rear end was for the original standard 3 speed. I now have a 350 V8 with the 350 automatic. Also I want to keep the original 6 lug wheels. I think the current original rear is 55” backing plate to backing plate or 62” wide at the wheel mounts. SO ..anyone know what year rear end is 6 lug with close to the same width? Frances Thanks Cadman | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I've got a '70 Chev 1/2 ton in my AD. 3:08 and 6 lugs.
Go to Tech Tips (at the top of this page) and look under axles. All the homework has been done for you. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Do you have any idea what's going on with it? The '56 GMC used a Spicer 45 rear (same as Dana 44), parts are still available, as are different gear ratios. you may want to consider overhauling the existing rear and do a gear swap while it's apart. That will avoid any fitment issues that may come up by changing the entire rear.
Bill Burmeister | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | That's good news, Bill. I didn't realize that the Spicer 45 was the same as the Dana 44 or that gear sets were still available. I would like to get some better highway gears for my '58 GMC. Does anyone know of a good source for gear sets? I would like to see what ratios are available. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Randy's Ring and Pinion http://www.ringpinion.com/PartsList.aspx?SearchMode=Make&MakeID=3&MakeName=GM+%2f+GMC+%2f+Chevrolet+&ModelID=290&ModelName=1%2f2+Ton+GM+Pickup&Side=Rear&DiffID=15&DiffName=Dana+Spicer+D44&CatID=10&CatName=Rings+%26+Pinions&CatType=Sub-Differential
Bill Burmeister | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | You will find the spicer 45 and dana 44 have very few interchangeable parts. GMC 1/2 tons that rolled out of the factory with a 3 speed most likely had a 3.07 rear ratio. 1/2 tons with 4 speeds or automatics had the 3.90 ratio. | | |
