3 members (Hotrod Lincoln, Wally / Montana, Southerntruck), 72 guests, and 2 robots.
Topics128,060
Posts1,055,831
#41622 10/24/2003 7:40 PM
Junior Member
Junior Member
Where is the temperature sender located on a '59 235?
#41623 10/25/2003 4:16 AM
Should be top rear of the head on drivers side
#41624 10/25/2003 5:13 AM
The temp sensor/sender is located either in the head front or rear (drivers side) like Whitelightning mentioned or they can be in the thermostat housing smile
#41625 10/25/2003 6:31 PM
I have a 56'-59' 235. Mine is located on the driver's side 'block', not head 3/4 of the way back from front (towards driver) directly below the throttle linkage. It is then flex-tubed (metal) up through the firewall and into the guage cluster.
#41626 10/25/2003 9:36 PM
Rattletrap52,,, is there a place for the temp sender on the head?
It should go in the head as the lower part of the block will not have an accurate reading.
Do you have a picture of the one you have?
#41627 10/25/2003 11:22 PM
Rattletrap52', I think what you are looking at is the oil pressure guage tube.
#41628 10/26/2003 2:47 AM
I am wondering the same thing you are cletis,,,
#41629 10/27/2003 3:06 PM
Junior Member
Junior Member
Yup, the temp sensor was on the top rear driver side. The one down low with the metal tubing is for oil pressure.
Thanks!
