| | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41622 10/24/2003 7:40 PM | Joined: Sep 2003 Posts: 37 Junior Member | | Junior Member Joined: Sep 2003 Posts: 37 | Where is the temperature sender located on a '59 235?
Thanks | | |
#41623 10/25/2003 4:16 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Should be top rear of the head on drivers side | | |
#41624 10/25/2003 5:13 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The temp sensor/sender is located either in the head front or rear (drivers side) like Whitelightning mentioned or they can be in the thermostat housing
#41625 10/25/2003 6:31 PM | Joined: Jan 2003 Posts: 26 Member | | Member Joined: Jan 2003 Posts: 26 | I have a 56'-59' 235. Mine is located on the driver's side 'block', not head 3/4 of the way back from front (towards driver) directly below the throttle linkage. It is then flex-tubed (metal) up through the firewall and into the guage cluster. | | |
#41626 10/25/2003 9:36 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Rattletrap52,,, is there a place for the temp sender on the head? It should go in the head as the lower part of the block will not have an accurate reading. Do you have a picture of the one you have?
#41627 10/25/2003 11:22 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Rattletrap52', I think what you are looking at is the oil pressure guage tube. | | |
#41628 10/26/2003 2:47 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I am wondering the same thing you are cletis,,,
#41629 10/27/2003 3:06 PM | Joined: Sep 2003 Posts: 37 Junior Member | | Junior Member Joined: Sep 2003 Posts: 37 | Yup, the temp sensor was on the top rear driver side. The one down low with the metal tubing is for oil pressure.
Thanks! | | |
