Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Sjm, Stovebolt48, Otto Skorzeny), 177 guests, and 4 robots.
Topics128,278
Posts1,058,457
Members48,490
I have noticed that used 3 phase air compressors seem to a bargin in dollors per cfm. I am moving soon and called the electical company to see if it would be avaialbe at the new place. They left me a message this am and I'll summarize it using round numbers. The closest three phase was 2.5 miles away or about 11,000 feet. This would cost $90,000 to bring out, but I could pay for over 18 months at $5,000 a month. Pretty cool huh? I have decided to get a single phase compressor, even if it costs a little more.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
Wow....what a deal! There are devices called AC Inverters or frequency drives that allow you to generate the third phase from a single phase input.
These are NOT rotary/static converts but solid state, programmable drives. The abound on e-bay and are pretty cheap in the small HP's.
I have several in my shop powering a three phase lathe, Bridgeport and drill press. There is no 'free lunch' electrically speaking, but one of these devices allows you to find a slightly larger air compressor at the dime-a-dozen three phase price.
Stuart
The 3 phase inverter for my lathe cost about $100.
Cletis,
I'm guessing you find that a bargain. With an inverter you can get over speed up to 300hz if you want, dynamic braking, acceleration and deceleration and about a million other things, including motor protection.
Want your lathe or mill to go faster or slower, presto, turn the little speed pot you installed next to the start/stop station.
These things are very cool. dance
Stuart
I went the other way, I have one commercial rotary phase converter, which is nothing more than a static converter plus a 5 HP idler motor. This would allow you to drive anything in your shop up to something less than the 5 hp.
I have also made a unit, and there are free plans on the internet for making anything from a simple static unit to a fully automatic unit. I will be making another larger unit to drive my 3 phase welder when I finish building my shop. This unit will have a 10 hp idler, or 2 5 hp units if I can't find a 10.
I have some links, if there is someone interested in learning how they work or want to make one.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
Sounds like a similar problem, we are about 2 miles away from 3 phase, and when we asked 5 years ago it was $24,000 to get it here.
I have two converters, one commercially built 10 HP rotary that works fine.
When I got my 15 HP lathe I needed more, so I built a rotary 15 HP converter at very little expense, and will do it again if I ever need another converter.
We have a total of about 40 HP worth of three phase tools, and occasionally will run over 30 HP at a time.
We started with the converter, and as the shop grew and tools got bigger we wanted to upgrade to real power, but for the cost it's not worth it.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
A lot of woodworkers are using these:
http://www.factorymation.com/s.nl/it.A/id.198/.f?category=32
However, you probably want a bigger than 3 hp unit, but the Westinghouse/TECO drives are a pretty good bargain.
Paint & Body Shop moderator
Moderated by  MNSmith
