3 members (hardshell, klhansen, ShopRag), 44 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
i found the old girl dead this morning....new battery was dead...put in another and found the generator turning...which would have killed the previous battery.....any have this problem before....one problem fixed...now another one..........
Butch,
The third relay in the voltage regulator is called the cut-out relay and it's suppose to open when the engine is turned off which opens the connection between battery and generator.
If this doesn't happen, the battery 'motors' the generator...turns it into a small DC motor and turn its.
This contact can weld itself shut causing this problem. I don't know if you can repair or file the contact back to life!
More knowledgeable folks will be along soon.
Stuart
thanks stuart........im going to dig into it tomorrow morning...first time ive had this happen.......after i found the dead battery i put the new one in and once i made the battery connections the generator started turning....i didnt have the belt tight thank god.....because if it was tight i wouldnt have know it was the generator.....it kind of surprised me to see it turning once i connected the battery terminals.....
You might need to polarize the generator/voltage-regulator (the simple procedure is described in the Shop Manual).
This can happen when you have disconnected/replaced the generator or voltage regulator; or, if your battery has been recently replaced (and your truck had not been run in a long time).
