| | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 45 | I have a Rochester carb with a tag on it that is labeled 7013029. Can anyone tell me which carb this is and if it will be sufficient for a 261?
The web page TheCarburetorshp.com lists it as a Rochester "B" originally being on a 235. I'm curious if anyone has run this on a 261 and how well it worked.
Jim
| | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | There is a SIGNIFICANT venturi difference between the 261 and 235 carburetors; I wouldn't use it on a 261.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2007 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 45 | My carb man says that this particular carb will work fin on the 261. Does anyone have any experience with this particular carb? | | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | It will work fine, as long as you don't mind 216 power, and 396 fuel mileage.
