3 members (RLB, Guitplayer, walter74), 96 guests, and 2 robots.
Topics128,055
Posts1,055,783
#414408 05/19/2008 7:51 AM
I have a Rochester carb with a tag on it that is labeled 7013029. Can anyone tell me which carb this is and if it will be sufficient for a 261?
The web page TheCarburetorshp.com lists it as a Rochester "B" originally being on a 235. I'm curious if anyone has run this on a 261 and how well it worked.
Jim
Jim A #414425 05/19/2008 12:27 PM
Carburetion specialist
There is a SIGNIFICANT venturi difference between the 261 and 235 carburetors; I wouldn't use it on a 261.
Jon.
The Carburetor Shop
My carb man says that this particular carb will work fin on the 261. Does anyone have any experience with this particular carb?
Jim A #417041 05/27/2008 3:50 AM
It will work fine, as long as you don't mind 216 power, and 396 fuel mileage.
Jon.
The Carburetor Shop
