1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41401 05/14/2004 5:45 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | This is about my el camino.
I've been having trouble keeping her cool - let me explain. Keep in mind it's a mildly hopped up 350 with headers, and a TH350.
First - when I had NO shroud, and the fan was 8 inches away from the radiator - it ran hot all the time - 220 on a hot day was not unrealistic.
Since then I have added a shroud and a spacer on my fan - it now get's to around 200 in town in traffic. Better. But still a little warm IMO.
Here's my question - I think I have a 165 thermostat in there. This causes it to be open nearly all the time - thereby not allowing the water in the radiator time to cool sufficiently before it get's cycled back into the motor.
If I put a 180 or 195 in there - do you think that would help my cooling? Seems backwards at first but it makes sense I think - by keeping the water in the motor longer - thereby allowing the water in the rad to cool more - when the gates do open - wouldn't that keep my temp lower cumulatively?
- Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
#41402 05/14/2004 6:26 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Ryan: Use the 190 deg. it will help. Also with a hopped up 350. My boys and I have found the new Water pumps and racing type fan blades work great to keep our stock car cooler. We was having a problem with 350 400hp stock car. Now corrected and getting all the ponies to work together. popcorn The Truth is Out There (Keep us posted) Ben | | |
#41403 05/17/2004 4:55 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Thanks - I"ll give it a shot -
The parade this weekend nearly killed the car!!!
- Ryan
