0 members (),
123
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 29 New Guy | | New Guy Joined: Aug 2006 Posts: 29 | Can anyone tell me what year(s) rear axel would work to switch my 63 from a six bolt to a 5 bolt patten? I couldn't find any info. with a search.
Thanks, Rick | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you swap out the side gears in the diff to the later 30 spline, you can use the '71-'76 axles. They will need shortened a bit due to the width difference, and regrooved for the C locks. I don't recall the exact dimension, perhaps 1/2" per axle? Then use the drums from the 5 lug axle with your existing brake assebley.
Bill Burmeister | | | | | Joined: Aug 2006 Posts: 29 New Guy | | New Guy Joined: Aug 2006 Posts: 29 | I do have a pair of 76 axels that I pulled out today and found them to be the approx. 1/2 inch to long you stated. I didn't think about making them shorter, may have to look into it. I was hoping to find an easier way, but will consider. Thanks, Rick | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Any machine shop should be able to shorten/regroove them for you. Actually, swaping the axles is easier, as you won't even have to rmove the old housing from the truck. It's maybe a 20-30 minuit job to swap the gears and axle shafts. Throw in some new seals and a gasket, some gear lube and you're on your way.
