1 members (baldeagle),
70
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HI...what are the benefits of a 1 wire alternator if any? Are there complete kits out there for my 1955-57/235 engine with 12 volts? We have never seen this conversion and have only just heard that it can be done DIY so its all new to us...T/C Steve | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Steve,
I don't know who makes the brackets for a swap to the 10SI alternator but I think someone does. Maybe MAD Electrical!
About the only real benefit to a single wire alternator is less wiring...one wire versus three wires. It's the same physical unit with a different internal regulator. If you want a bazillion amps, you can get it either way...1 wire or 3 wire.
To get the alternator to start its charge, you need to bring the RPM's up a bit, but this is usually done by habit as you start your truck anyway.
Stuart | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | with a ONE wire alt you don't have the indication that something is wrong w/ it should it start to fail whereas w/ a 3 wire unit .......... you do you can read and decide for your self http://www.madelectrical.com/electricaltech/onewire-threewire.shtml http://www.6066gmcguy.org/charging.htm
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | WOW.....THANKS TC....now what to do...? I think you can still buy generators or have them rebuilt...? BUT...the alternator is always charging the battery and that can't be a bad thing. Does anyone know if it will affect my Langdon's HEI unit to move to the alternator three or single wire?.....T/C to you all! Steve | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Not a problem Steve. Your HEI just wants to have 12V fed to it, it doesn't care where it comes from. | | | | | Joined: Feb 2006 Posts: 4 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 4 | A quick note on the indicator light for a three wire... It is not optional.... the three wire unit will not excite without the resistance on that lead. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bugsy,
Are you indicating that DA#1 needs a reduced voltage, not full system voltage to excite the field? How can this be...many rigs don't opt to run an idiot light or a resistance in that circuit and everything runs fine. Isn't this right?
Stuart | | | | | Joined: Feb 2006 Posts: 4 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 4 | I'm sure I found it on the MAD Electrical site... I remember reading it before I converted. I didn't necessarily want to put the idiot light in the dash of the 48... It has been a while though... but I seem to remember the alternator not working until I hooked up the light.  | | |
