4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41291 03/01/2002 7:25 PM | Joined: Jan 2002 Posts: 18 Member | | Member Joined: Jan 2002 Posts: 18 | I'm putting my 235 back together and of course spent more than originally intended. I can't afford a alternator at this time so I plan to run my generator as it's in great shape. Will the generator produce enough amps with a HEI distributor and A/C? | | |
#41292 03/01/2002 8:39 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, assuming the generator is 12 volts. The AC only needs enough juice to run the fan and some relays. It just won't handle a big radio or lots of lights.
#41293 03/01/2002 8:51 PM | Joined: Jan 2002 Posts: 18 Member | | Member Joined: Jan 2002 Posts: 18 | Thanks. It is a 12 volt system, I'll only be running a CD player, no external amp, and stock lights. | | |
