3 members (1955firstseries, Roy Rodgers, elhippie64), 75 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#41241 10/04/2004 4:35 PM
mj
Offline
The 4 speed tranny in my 51 Chevy 3100 has these #'s on it.
left front A231
right rear GM 6
591568
Where can I look up these #'s to id this???
#41242 10/08/2004 12:54 PM
Junior Member
Junior Member
mj
If you go to Google.com and type in chevy casting numbers, you will get a lot of sights that will help you. You just have to sort to find the one you need. Also helps with engine identification.
Good luck.
Just another new hobby... but learning fast.
#41243 10/08/2004 8:32 PM
If it's got a ultra low, non synchro first gear then it's the SM420:
http://www.novak-adapt.com/knowledge/sm420.htm
http://www.jeeptech.com/convtrans/gm/gmsm420id.html
Keahi
