3 members (baldeagle, Eisenholtz, NJC), 119 guests, and 2 robots.
Topics128,037
Posts1,055,469
Members48,424
#411961 05/11/2008 10:30 PM
Apprentice
Apprentice
Anybody know the proper way to bleed the brakes on a 66 Chevy C-60. It has the power brake booster under the cab on the driver side. I dont have a pressure bleeder so I will have to do it the old way.The local Advanced auto parts store has a master cylinder to fit a 66 C-30 will that work if bleeding dont? Thanks Bob
ajhartle #411997 05/12/2008 12:42 AM
3B Offline
Hy ajhatle, a C30 master cylinder has too small a bore to work on a C60, I thought you were going to answer our questions about your truck, so we could give you the correct part number for your master cylinder.
3B #412034 05/12/2008 2:15 AM
Apprentice
Apprentice
I havent taken the Master cylinder off yet so I dont know the bore size.Im going to try and bleed them as soon as I know the correct way to bleed this type of system.
ajhartle #412095 05/12/2008 4:57 AM
You usually start with the furthest from the m/cyl, usually RR, LR,
RF, LF. if the master cylinder is dry, bench bleed it first....
GMC: Get More Cash...
1958 GMC
My Webshots photos
3B Offline
Hy ajhartle, procedure from the maintenance manual
1. bleed the power booster on the end [away from the diaphragm]
2. bleed the power booster next to the diaphragm
3. bleed the left rear
4. bleed the left front lower
5. bleed the left front upper
6. bleed the right rear
7. bleed the right front lower
8. bleed the right front upper
9. bleed the power booster at the end again
10. bleed the power booster next to the diaphragm again
as 1958GMCnut said if your master cylinder is dry, you would probably get better results if you bleed it first, hope that helps.
3B #412391 05/13/2008 2:06 AM
Apprentice
Apprentice
Thanks for the info. I glad I asked first cause I would of started on the right rear.
ajhartle #413542 05/16/2008 8:29 PM
Could I add that it is important to adjust the brake shoes first. If they are very far away from the drum it will complicate the bleeding process.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
Apprentice
Apprentice
