2 members (2-Ton, farmallb),
67
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41172 06/15/2003 7:17 AM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | The engine #'s are cast on driver's side, about centered, on my 1956 gmc 2-1/2 ton 424v. About halfway from there to the rear(same side) is a small plate. What is the significance of the markings on this plate(L215)? Also, above the casting #'s is the letter A with CWG below the letter A. What are these letters for? Thanks in advance.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
