6 members (Ridgeback, rick46ia, Otto Skorzeny, klhansen, MNSmith, 1 invisible), 109 guests, and 4 robots.
Topics128,022
Posts1,055,373
Members48,420
#411541 05/10/2008 6:13 AM
Before anything else, excuses for my bad english. I'm very happy to be here, among so many old truck experts/lovers. I have a brazilian made (by GM here) C-l416 Veraneio, almost a copy of the american '64 C-14 Suburban. Has a 261 engine, four-on-the floor, assisted steering and brakes (disc at front), A/C, and is in in very good shape. I'm working in it at some time. Will send some pictures soon. Now to my question: in order to make valve adjustment more comfortable (climate here in my country is somewhat hot), what if I warm up my 261, adjust only one pair of valves (no. 1 cyl. for instance), wait engine cool down, measure the gap of these two valves, and apply this measurement to the other 10,now cold? Will it work? Many thanks for any opinion or advice.
Welcome to Stovebolt.com
A similar question was recently discussed.
An adjustment procedure like this one has been suggested by many people over the years. This procedure is not messy and is as easy as the one you describe, Moreover, this type of procedure is done on a warmed-up engine, as suggested in the Shop Manuals.
Tim
Ai, carramba! Does it look like this?
http://djjaragua.vilabol.uol.com.br/veraneio.htm
Welcome to the site. If I tried your method, FJM, I'd do it on #2 or #5,because those are where the best average internal temperatures- and hence the best average differences between hot & cold settings - might be found, but I might be a bit obsessive; There's not likely to be much difference. Be advised that it is better to have them a bit loose than a bit tight.
Incidentally, your English is excellent.
1951 3800
-hotshoe
Welcome to the Stovebolt! We will look forward to your photos. I would like to see if there are many differences in the body style. I hope that you have a good time working with your truck.
I have checked my valve settings cold after they were set hot and I could not really see any difference.
1951 1 Ton Completed
hotshoe,
Pretty interesting license plate on the rig in your link! grin
Stuart
Shouldn't it say frijoles, juevos, cajones, or at least have an s at the end of teste? Maybe it's just got a 1 barrel carb. blush
Moving on... Welcome to The Stovebolt Page. You must be proud of your truck if it looks anything like the one in your link.
Good luck. Send pix.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Portugese, man, not Spanish! dang
Bill smile
OK - ovos, favas,... Now I am starting to question *my* English.
David Colter
Many thanks for the greetings, advices an comments,tclederman, hotshoe36,truckernix,atomarc, 54TOW and TxLaTx.
My language is,in fact,portuguese.But I understand Spanish well.
Hotshoe, the truck is exactly like the one in the link, except that it is 10 yrs. younger. The differences are minimal. You will see them in the photos to be coming soon, truckernix. Sounds really better to measure the gap (hot) in the middle cyls. I'll do it.
Muito obrigado a todos!(portuguese)
