4 members (Gray_Ghost, treegrower, Wickedbass, WICruiser), 76 guests, and 1 robot.
Topics128,076
Posts1,055,922
Members48,430
#410719 05/07/2008 10:39 PM
Apprentice
Apprentice
I have a 1960 GMC 1000 long bed step side. I have two new "gravel pans" as they are called, I think. Stamped sheet metal slight taper, identical pair. Where the :mad: do they mount?
Thanks!
Just learning...
longhaul #410721 05/07/2008 10:41 PM
Apprentice
Apprentice
Some catalogs list them as "dust shields", too.
Just learning...
longhaul #410965 05/08/2008 5:34 PM
I'm not sure on your 1960 GMC, but on older GM trucks, they mount behind the front bumper, to protect the grill from stone chips, etc. There would be only one, unless the "later" pans come in two pieces. The shield also makes a nice step to stand on when checking oil. That is, for those who aren't tall enough to reach over the fender.
They should have some attached brackets for attaching the pan to the bumper brackets. I don't remember them attaching to the frame in front of the grille, but maybe they attach there as well. Mounting brackets on the pan should indicate where they might attach.
Harvester
