5 members (Otto Skorzeny, KEVINSKI, Hanks custodian, SmalltownTRKGuy, 1 invisible), 69 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#4105 03/10/2003 6:26 AM
How do I tell the difference between 47-50 brake drums and 51 on(huck to bendix). Is there a change beween front and rears besides hubs? Thanks
Brian D
#4106 03/10/2003 10:13 AM
Look on the backing plate. The bendix has the adjuster slots at the bottom and the Huck has them up at the top on the wheel cylinder.
Paint & Body Shop moderator
#4107 03/10/2003 4:26 PM
The problem is I am looking through a stack of AD drums by themselves and would like to know how to tell them apart. Is the diameter and depth different?
Brian D
#4108 03/13/2003 6:36 PM
Brian do you need just the drum or do you need the drum and hub combo? I know the hubs are different but not exactly how. The drums if they are the same dimension (brake surface) should be able to be swapped. So what I would do is find a "good" drum that was the same size and swap out hubs.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#4109 03/14/2003 3:05 AM
Anonymous
Unregistered
Anonymous
Unregistered
Huck brake drums are ribbed [ on the area outside of the shoe contact ]. Bendix brake drums are smooth.
