3 members (CandoBrent, 2 invisible), 99 guests, and 3 robots.
Topics128,079
Posts1,056,286
Members48,441
#410357 05/06/2008 6:42 PM
i am doing the body work on my 46 2 ton the hump area on the back of the cab has rust thru the holes average the size of peas the
remaining metal seems quite sound and i had the truck sand blasted.
do you guys think that fiberglass strand body filler worked in
from inside the cab then regular filler on the outside would hold up . philip
I wouldn't use the body filler unless I had no other options. I would prefer to weld patches instead.
~Jim
