0 members (),
128
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i am doing the body work on my 46 2 ton the hump area on the back of the cab has rust thru the holes average the size of peas the remaining metal seems quite sound and i had the truck sand blasted. do you guys think that fiberglass strand body filler worked in from inside the cab then regular filler on the outside would hold up . philip | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I wouldn't use the body filler unless I had no other options. I would prefer to weld patches instead.
~Jim
