5 members (FAST55, MickeyP, mo2cyl, Gdads51, 66flea), 87 guests, and 1 robot.
Topics128,049
Posts1,055,652
#409865 05/05/2008 7:03 AM
I'm looking to replace a generator with an alternator on my '49. We have a new 261 going in. If I visit the local junkyard, which alternator am I looking for that will be internally regulated and will fit the aftermarket alternator brackets?
Ex Hall Monitor
Ex Hall Monitor
Are you converting to 12 volts? You can buy 6v internally regulated alternators on ebay and other places on line. I put one from these guys on my 38.
you'll need to figure out what it is you need from your truck, what electrics will you need to power &/or any future additions. but for most of us the 10 or 12 should work out just fine. you may have to make a plate to bolt your alt to @ the block to line-up the belt. i used a GM 10si - 12 volt
12 volt systems::::
also avail 12si, 12 ci
http://www.rowand.net/Shop/Tech/GmAlternatorIdentification.htm
there are one wire and three wire hook-ups.
my .02 is for the three wire wink
http://www.madelectrical.com/electricaltech/remotevoltagesensing.shtml
http://www.6066gmcguy.org/charging.htm
some good info here...
Jim & Caroline
I'm switching to 12 volts.
The article in that link is excellent! I now feel like an alternator expert and I'm off to go alternator hunting.
Thanks much.
Jim
