| | | Forums66 Topics128,049 Posts1,055,665 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 45 | I'm looking to replace a generator with an alternator on my '49. We have a new 261 going in. If I visit the local junkyard, which alternator am I looking for that will be internally regulated and will fit the aftermarket alternator brackets? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Are you converting to 12 volts? You can buy 6v internally regulated alternators on ebay and other places on line. I put one from these guys on my 38.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you'll need to figure out what it is you need from your truck, what electrics will you need to power &/or any future additions. but for most of us the 10 or 12 should work out just fine. you may have to make a plate to bolt your alt to @ the block to line-up the belt. i used a GM 10si - 12 volt 12 volt systems:::: also avail 12si, 12 ci http://www.rowand.net/Shop/Tech/GmAlternatorIdentification.htmthere are one wire and three wire hook-ups. my .02 is for the three wire http://www.madelectrical.com/electricaltech/remotevoltagesensing.shtmlhttp://www.6066gmcguy.org/charging.htmsome good info here...
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Dec 2007 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 45 | I'm switching to 12 volts.
The article in that link is excellent! I now feel like an alternator expert and I'm off to go alternator hunting.
Thanks much.
Jim
