I'm not sure about the weight issue but as a rule,the lower the tire profile the firmer the ride. I am assuming the tires are 50 profile or less.
Bear in mind these tires were designed for lighter 'nimble' sports cars and as a result have much less sidewall 'flex'.
They are always going to be a compromise between looks and comfort.
It might be worth looking up
www.momo.comto see if your wheels are on their site. It may give you load ratings. Watch though,it'll probably be in metric!
As LONGBOX55 said,your overall drivetrain/suspension setup will also have a bearing on the ride quality.
Hope this helps
Jock
