2 members (TUTS 59, Wayne67vert), 97 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#4096 02/26/2005 6:46 PM
Does anyone know what head will interchange on a 1978 250 engine so I could run a 2 or 3 carb intake? My head has the intake molded into it! Thanks,
#4097 02/26/2005 10:38 PM
Riding in the Passing Lane
Any 74 on back 250 will fit. The 194, 230, & 292 fit also but might change the comp. ratio. If you have power str. Or a/c the brackets will be different. Get an 71 up head they have better valves & seats for no lead gas. Also the exhaust hook up will be different. smile
1972 Chevy c10 Cheyenne Super
#4098 02/27/2005 12:40 AM
The non-integrated manifolds ran longer than '74. My 250 engine is from about '76, separate manifold. I've seen a few even later than that - they seemed to be using up old stock here and there. Best bet is eBay or your local wrecking yards.
The best use for that integrated manifold POS is a boat anchor.
1954 GMC De Luxe COE
#4099 02/27/2005 5:30 PM
Wow, Thanks guy for the info! I've always wanted to do a 6 cyl "up right" after doing so many small blocks, this will be fun.It's going into a 37 Chevy 1/2 ton.
#4100 02/27/2005 9:25 PM
Get Santucci's Inline 6 Power Manual! Just about everything you need to know to build a hot L22 6.
