| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 20 Apprentice | | Apprentice Joined: Jun 2007 Posts: 20 | In my experience, fan shrouds serve a purpose. Did the 1960 GMC pickups (305a) have a fan shroud? If so, where can I get one, as my truck doesn't have one...
Just learning...
| | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I don't know about the GMC, but I do know the '60-'61 Chevy C10 had a fan shroud that looked like the passenger car shroud. The '62 had a beefier, more stoutly built fan shroud, but it still looked like a barrel stuck to the radiator. '63-'66 also had a shroud; 3-piece style, with side skirts that removed.
I've seen both the '60-'61 style and the '62, and for my truck I prefer the '62, which should bolt into the earlier ones.
I would suspect the GMC versions are the same, since the core supports and all the front sheetmetal are the same.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jun 2007 Posts: 20 Apprentice | | Apprentice Joined: Jun 2007 Posts: 20 | Thanks. I don't why folks (prior owner) take these things off, they do serve a purpose!
Just learning...
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | installed one on my 57. got it from classic parts of america. 92 bucks with shipping. OUCH !! since my temp gauge dont work, dont know if it helped at all, since my truck dont run hot anyway. but looks better with than without, and will save my fingers when working under the hood when running. LOL. took a bit of fabricating, cutting, to custom fit, but i am happy witht he results. leonard | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Interesting... I checked with Chevy Duty, Obsolete Chevy, Brothers, and LCM. They all sell rad shrouds for 59 - 63 and up but no 60,61, or 62. Weird. Check with NAPA.
~Jim
| | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Yeah...pretty much anything for '60-'62 is off the radar! My theory on why they're always missing is pretty simple: They have to come off to change the water pump. First the shroud is unbolted, then pushed back to the engine block. Oops...you have to remove the fan belt first. Okay, that's done, now you can get your fingers on the fan blade's bolts and remove it, using the radiator as a cheese grater on your knuckles. Fan's off, now you have access to the water pump. Swap out the water pump, get the fan belt back on, install the fan and...oh crap...there's the fan shroud still on the work bench. Either that, or they just didn't like dealing with the fan shroud and left it off deliberately. Same process for a radiator repair.
-Brad
SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | yea, its a pain to work around for sure. i cut the bottom of mine in half, and made a bracket to bolt the two together. like my old 1970 chevelle had, if i rememebr correctly. the shroud itself was 70 bucks, the rest, 22 dollars was shipping. dont know how they get 22 dollars to ship a plastic fan shround, and SID only charged 35 dollars to ship my 55lb complete front axle... leonard | | | | | Joined: Jun 2007 Posts: 20 Apprentice | | Apprentice Joined: Jun 2007 Posts: 20 | Yes-I have done the same. I have found fan shrouds to be really important at slow speeds.I got a used one off of ebay, but I am not sure it is the right one, as it is bigger than the radiator itself. I will give it a try-I appreciate all of the input. I am trying to find a pic of a stock one, as that will help...
Just learning...
| | | | | Joined: Jun 2007 Posts: 20 Apprentice | | Apprentice Joined: Jun 2007 Posts: 20 | Well, the ebay one won't fit! If anyone know where to get one, I'd appreciate the input. Runs fine now, so I'll just keep looking! Always something!
Just learning...
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | have you checked at your local salvage yard? I'd suggest checing under the hoods of old school busses and perhaps 1 1/2 and 2 ton trucks. They seem to always have one on them. I adapted one from a '58 school bus to fit my 1/2 ton, wasn't to hard to do, I had to add a couple of L shaped adapter peices to the sides to fit my core support.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | longbox55, do you have any pics of your shroud you could post ? thanks. leonard | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | This is the shroud (along with the 5 blade fan from the same bus) as I got it. I'll get some pix of it installed. http://rides.webshots.com/photo/2184834800092261295OoCpbP
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks bill. from that original pic or the shroud, the fibergalls one i got from classic is at leasdt twice as think. thanks.. leonard | | |
