| | | Forums66 Topics128,181 Posts1,057,152 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 13 New Guy | | New Guy Joined: Apr 2008 Posts: 13 | I just spent an hour searching but have not came up with much info. Hoping someone can point me in the right direction. I'am trying to find out what my options are for changing the gears in my 49 3600 rear end. What has anyone else done? Are there any ring and pinions (I tried Patricks and Randys ring and pinion)that are available or is there another model 8 lug axel that will fit?
Thanks in advance
Chris
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This has been addressed a number of times. You will probably have a ratio of 4.57 in your truck. There are direct bolt-in "pumpkins" or the complete gear assembly of the rearend from 3/4 Ton GM truck from 67 to 72, with automatic transmission, that will give you a 4.10 ratio. If you go on the Jim Carter site, he has a technical description. The only tricky part is finding one. I put one in my 1 Ton and it works really well. You can do a search for "410 gear" and you will get a lot of hits. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | A 5.17 ratio was an option in 3/4-ton trucks and standard in 1-ton trucks. You are not clear which direction you are trying to go...
If you need something more highway friendly than 4.11 you probably need to swap rears. I've been told there is a 3.something out there, but no one ever seems to be able to find one.
I'm not sure what else would fit, but if you take a tape measure to the wrecking yard you should be able to find something close to the right width.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You're pretty well stuck with those low gears unless you swap rears with something later that will fit your 3/4 ton.
~Jim
| | | | | Joined: Apr 2008 Posts: 13 New Guy | | New Guy Joined: Apr 2008 Posts: 13 | Thanks for the info I will try that. | | | | | Joined: Apr 2008 Posts: 13 New Guy | | New Guy Joined: Apr 2008 Posts: 13 | Yeah trying to find something more road frendly, told now there is 4.56 gears in the truck. | | | | | Joined: Apr 2008 Posts: 13 New Guy | | New Guy Joined: Apr 2008 Posts: 13 | Thats what I was afraid of. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I swapped to a 81 Camaro 10 bolt. Of course your lugs won't match your front. If that is a problem you can either install a mustang II or weld on a clip that gives you 5 lugs. There may be a kit to swap your 8 lug to 5. It seems like I remember a discussion on that here in the past. Someone will be along to answer that question i am sure.
~Jim
| | | | | Joined: Jan 2008 Posts: 17 New Guy | | New Guy Joined: Jan 2008 Posts: 17 | Try searching Dana rear ends. I put a dana 60 with 3:54 gears in my 3600. Some did come with Dana rear ends. I wanted to keep it a 3/4 ton so I went that way. It was a simple bolt in with minor mods. Kept the 8 lug configuration. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | That Camero rear end should be the standard 5 lug Chevrolet bolt pattern. If you can give me the casting or part number which is cast on your front axle, I might be able to give some options regarding the front axle and matching it to a Camero rear axle. That casting number is on the front or back face of the axle on the flat between the top and bottom part of the "I". Matching five lugs all the way around shouldn't be too bad if you can get some decent rear gears. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
