| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | I was looking thru several of my catalogs and was unable to find the brackets that hold up the running boards, the ones riveted to the frame. I need the first one in the front on the drivers side. mine is broken. are these available? | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | I see 'em on eBay now and then, check with Jimbo59 in the parts for sale section, or Jay in CA. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | As far as I know you have to find used ones, as no one makes new ones.
Grigg | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I bought mine on Ebay and they were just like new. Sometimes it take some time before they appear on Ebay. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Be careful buying them sight unseen, I bought two last year that were supposed to be in excellent shape and when the got here they were heavily rusted with deep pits all over the entire surface. The holes were burned where he took the rivets out with a torch. I ended up using my old ones which were not rusted and just straightened them. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | maybe I will just repair the one I have that has the ears at the top broken off. the pieces are still attached to the frame. just remove it weld it up and maybe add an extra set of bolts for added security | | |
