| | | Forums66 Topics128,078 Posts1,055,935 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I am wondering on vin plates for the 1 ton, 1.5 ton, and 2 ton does it say Chassis No., or does it say Serial No.? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | | | | | | Joined: Mar 2008 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 25 | The id plate located on the drivers side hinge pillar states "serial number" just above the actual number which is at the very bottom of the id plate. | | |
