0 members (), 348 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,463
1 Offline
toyota truck frame under a 50 3100 if so any problems i should look out for thanks in advance for the help
Look out for irate stovebolt owners with buckets of tar, feather pillows, pitchforks, and torches!
I would hazard a guess the axle width would be just a little narrow, and the wheelbase might be a bit short, depending on the model of Toyota you're considering. Try parking the Toyota beside your stovebolt, and doing a little eyeballing and measuring. Just about anything can be adapted with enough time, money and effort, but you might consider going with some of the more conventional retro-fits like an S-10 frame.
1 Offline
yeah i hear you not many reg cab long bed around here for cheap just seeing what else i might be able to use kinda on a budget
guess toyota rails are almost the same as 32 ford rails
What model of Toyota are we talking about?
