3 members (jmoore, gswbbc, Lightholder's Dad), 67 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#40245 11/21/2003 1:10 AM
I have the choice of putting a 3 speed or a four speed (both are 46 units) in my truck. You people with experiance, which one would you use? Also are these syncro transmisions? Anyone care to vote? Thanks for you input!
No hill for a climber!
#40246 11/21/2003 2:07 AM
On the 4 speed, I assume you have the one with the reverse lever on the stick. That's not the tranny I would choose. Both trannies are synchro except for first gear, and since second gear in the 4 speed is about the same as first in the 3 speed, that is an advantage. Reverse in the 4 speed is considerably lower than the 3 speed, which I like, but that's a personal preference. Granny gear is rarely used, but nice to have. If it were me, I would get the SM420, 4 speed from the 48 to 66 model, which doesn't have the lever, and is a good tranny.
Fred
52 3600
69 C-10
#40247 11/21/2003 2:56 AM
Thanks for the reply. I know wgere there is a 57 5 window. Would this truck have this trnas? Also what is the advantage to convert using this one. One more thing, what engine would the 57 likely have? It is 1 3/4 ton.
#40248 11/21/2003 4:16 AM
The '57 should be an SM420 if its a 4-speed. That transmission was used until sometime in the '60s.
Be aware that the '57 had an open driveline, and your '46 would not.
#40249 11/21/2003 4:24 PM
If it''s a six, the 57 should have the 235 with the SM420. Open driveline, too. Assuming your truck is a 1/2 ton, I would also find a later model differential and convert. You will have to do some driveshaft work, too. Iirc, the 4 speed had a bigger rear shaft than the3 speed.
Fred
52 3600
69 C-10
#40250 11/21/2003 5:12 PM
red rock:
If it were me, between the two I would choose the 3 spd. I think you'll find yourself diong a lot of double clutching with that 4 spd. It's not syncro in any gear. I've got the 3 spd in my 46 1/2 ton and it works just fine. Still no syncro in 1st, but thats not a big deal.
Go with what makes you happy, if you do decide to go with a newer trans and you are going to dump that 3 spd, let me know. I can always use a spare.
George
#40251 11/21/2003 6:42 PM
I've never had to double clutch the SM420 in my 61, or any other 4 speed I've driven for that matter. SM420 4 speed is definately the transmission of choice. There's one going on ebay right now.
http://cgi.ebay.com/ebaymotors/ws/e...1&category=33733&item=2443546206
"If the women don't find ya handsome, they should at least find ya handy!"
1961 Apache 20 4x4
http://community.webshots.com/album/97352016vHsKNP
#40252 11/21/2003 8:14 PM
The stock 41-46 4 speed trans does NOT have synchromesh
gears and does require double clutching or skillfull manipulation of engine RPM to shift. The 41-46 3 speed is synchro in second and third. The 3 speed is much easier and faster to shift and weighs less than half the 4 speed.
If you elect to use the later model trans, you will need to change the rear end, at least the pumkin, the driveshaft, and your brake and clutch pedals and master cylinder will have to be custom mounted or changed as they normally mount to the 41-46 transmission.
#40253 11/21/2003 10:22 PM
You can avoid changing the rearend by using a pre-'55 SM420 out of a 3100.
Paint & Body Shop moderator
