3 members (cmayna, Ponchogl, Hotrod Lincoln), 105 guests, and 0 robots.
Topics128,126
Posts1,056,351
Members48,441
#40198 11/26/2002 5:59 PM
A question for the River of Knowledge!
There is a 3 speed and overdrive in the swap meet and I was wondering if I could use the overdrive on the 4 speed on my truck? I would like to have highway speed for the thing. A good bud of mine has a Pherd 350 box van and we just put an overdrive (gearvendors) on it and it works great.
Thanks.
#40199 11/26/2002 8:59 PM
I have heard of this being done, although it is not trivial. You need to contact Patrick's (see link section) for the parts needed.
Paint & Body Shop moderator
#40200 11/27/2002 4:36 AM
thanks, as the thing comes with a 3 speed, I would think if I used that box, then it would bolt up and I could just go with overdrive and 3 speed, or I could maybe go gearvendors....
something to think about....
#40201 11/27/2002 6:23 AM
Or change the rear end gears,which is a simple 1 to 3 hour job with the parts on hand.Everything is bolt in and available
#40202 11/27/2002 4:29 PM
Mechanic, the final drive is a good way to go, most of the time. I have a 4 sp overdrive that is great out on the road. But the 1st and reverse gears are really fast. It can be hard to get started, with with out slipping the clutch, with a load or on a grade. I am thinking of using my straight 4 speed with the grannie low, and using a 2 sp OD box behind it. I know that will hurt the fuel efficency some, but it will save the clutch. Mike
#40203 11/28/2002 3:44 AM
Pardon my ignorance, but who has the parts?
This truck has the 1 ton rear end which has the big 8 lug drums and is of the 'full floating type' with 5.14 to 1 gearing according to my 1959 chevy truck operators manual.
I have seen patrick's gears, etc, for a 1/2 ton, but that series has a different diff. and I didn't see any gears available for my truck.
#40204 11/29/2002 1:41 PM
The OD from the three speed will not bolt up to your 4 speed. If you want a HD overdrive I would suggest the gear vendors as long as you have some $$$ hanging around. Think they start around 1K.
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
#40205 11/30/2002 5:05 AM
smile howziit guys!
at www.gearvendors.com prices start at $2195. eek eek eek
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#40206 11/30/2002 6:25 AM
Cheapest swap is to go with a 14 bolt full floater from a late model 3/4 or 1 ton. You can easily find one with 3.73 gears. There are even a few with 3.42 gears. You will have to be careful with the width if you have a pickup bed, with a flat bed it's no big deal. Also, some late model wheels have deeper setback.
Fred
52 3600
69 C-10
#40207 11/30/2002 7:39 AM
Thanks Fred, that's a good idea. I can check the local boneyards for a newer rear end. Today I was hacking the box up with the blue flame speed wrench. I should have it apart in next couple of daze. I have a bud with a gearvendors on his Pherd 350 17 ft box van and its quite nice, but dunno if I want an overdrive worth more than the truck! I think even with the lower gearing out back, the granny should still get any load moving, and with the bed gone, I can do what I like. wink grin :rolleyes:
#40208 11/30/2002 7:54 AM
One thing I forgot to ask, Fred, can you tell me how to identify the rear end and what markings to look for to see what gears are in the rear?
#40209 11/30/2002 9:11 AM
I know someone who has a 4.11 ratio rear end that will swap into your present rear end housing.
All a person has to do is drop the drive-line,pull the axle shafts outa little ways to clear the differential when it comes out.Drop in the differential unit and bolt it up.bolt the axles back in,fill it with gear oil(85-90W) and re-connect the driveline.
You will have to live with the speedo being off or locate a gear reduction for the speedo cable at the transmission.
#40210 11/30/2002 6:27 PM
Irwin, to check your rear axle gear ratio, try this:
"Jack up one tire if you have an open diff, or both tires
if you have a working posi or locking differential. Rotate the
tire one full revolution for posis and lockers and 2 full
revolutions for open diffs. Carefully count the number of full
revolutions the driveshaft makes. This is your gear ratio. In
other words, if the drive shaft turns 3 & 3/4 turns, you
probably have a 3.73 gear ratio. Turning the tire for twice the
number of full revolutions and dividing the drive shaft
revolutions by two will give you a more accurate
reading." (quoted from West Coast Differentials)
You may have 5.14's or 4.57's. A 4.11 pumpkin should swap in and be much smoother on the highway without sacrificing your load carring ability too much smile . I think 3.42's might be too tall, but if matched to the appropriate trans; no problem. cool
*** GMC ***
#40211 12/01/2002 9:40 AM
Thanks guys, great info, what would I do without ya!
I am 90% certain that I have 5.14 original equipment in this thing. I hope to finish slice and dice on the bed in the next couple of daze.
Then I can look at rear ends. The engine is going from a 235 to a 292, so the 40 hp increase (135 to 175 (maybe - used motor - but runs)) ought to make the difference. I don't think I will be hauling any huge loads with this - probably go to a flatbed, maybe try to find one of those 3.73 rears. Although, 4.11 is a decent option too. I have already had one of the axle shafts out of it, so I know that's no big.
In fact, the nice thing about this truck is that everything is 'no big'. Unlike my previous techno showboat - 90 Mark VII with supercharger, where I had to unbolt the blower just to get to the plugs.
Today I slapped some 0-rust on the bumper, grill, and other bits (white).
So whaddyer think? Paint the wheels red, black, or white to go with red cab?
#40212 12/01/2002 2:28 PM
Irwin-what about one of those NV 4500 O.D.'s from a newer big truck? Might work-I seem to remember someone here did this swap.
Just my $.02, I'd go with red wheels-white would be "too much," while black would make 'em "dissappear" into the tires.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#40213 12/01/2002 5:24 PM
Irwin, here is some info on the NV-4500 .
I think they go for $1500 or so,; they are a very hot item.
It's hard to beat the SM-420 or the SM-465. You can try, though!! :p grin .
Very tough trannies. Since you are going with a newer engine, you can get a B'house for it with the 5-1/8" bearing retainer opening. Then you can run an SM-465 cool .
I think Chief has one in his truck; 502 BBC in the front of the -465 and a Gear Vendors unit on the back! If money was no object, I would get a Gear Vendors unit for my truck. I have 6.13 gears (in high range) and 8.10 in low.
*** GMC ***
#40214 12/01/2002 8:02 PM
Wow more choices, yer corn-fusin me!
Great info though, I didn't know squat about the other transmissions available. For free truck this old bird's really getting the treatment.
I just read oldkarkook's bit on getting 4.11 gears for my rear, and so I might scout about and see if I can do that, then go from there.
I'll probably run it about the block to see how it does with original gears when I get there just out of curiosity.
#40215 12/02/2002 4:52 AM
While the NV4500 is a great tranny, it has one major drawback, the speedo setup is electronic.
Looking at Lukes suggestion about dropping in a 4.10 pumpkin, I went back and saw that your truck is a 59 model. Luke's right about a pumpkin swap being your easiest and cheapest upgrade. combine the 4.10 gears and tall tires will give you decent rpm's on the highway. I would also go with the SM420 or SM465 tranny, go to Nowak tranny page for more info on these gearboxes.
Sounds like we both have similar plans for driveline. Mine (hopefully) will have a 292, tranny will be either a SM465 or 700R4, with a 14 bolt rear, gears either 3.42 or 3.73, depending on which tranny I opt for. good luck.
Fred
52 3600
69 C-10
