5 members (55shaker, Woodcmiami, Gib70, Phak1, 3B), 105 guests, and 1 robot.
Topics128,115
Posts1,056,626
Members48,450
#4009 09/16/2002 6:05 AM
I just recently acquired a 1950 suburban. I am looking to take out the 216 and drop in a 235 that I plan to modify with some performance options. Will I need to upgrade my transmission and rear end to accomodate the added horse power? :confused:
No. You will not need to upgrade to accomodate the added horse power.
However you will want to upgrade for speed and mpg.
You probably won't want to cruise your 235 faster than 2600 rpm. With stock tires (29" O.D.) and stock 4:11 rear end, that will give you 55 mph. You can replace your 4:11 ring & pinion gears with Patrick's 3:55 r&p (about $400 at most vendors) to get 65 mph at 2600 rpm. Taller tires can bring that up to 70 mph.
If you want to lose your torque tube driveline, you can get an adaptor for your tranny, have a new driveline fabricated, and swap in a newer rear axle of similar width to your current one. You'll have to weld new perches on the new rear axle, and chances are that the lug nut pattern won't be six bolt. For more info read Jim Forbes article at chevytrucks.org and of course be sure to check out the Donor Rear End Measurements article here at Stovebolt.com.
Barrett Revis
'53 3105
'48 3105
The fewer the moving parts, the less there is to go wrong...
