Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TUTS 59, Steelbee, Hotrod Lincoln, KEVINSKI), 133 guests, and 2 robots.
Topics128,285
Posts1,058,533
Members48,490
Junior Member
Junior Member
Just wanted to know that if I swap my L6 250 for a V-8 can I use the same Motor Mounts??? I have a 66 C10 fleetside. Thanks, Owen Owease@aol.com
U
U Offline
The V8 mounts are not the same as the L6, but I have heard you can use them. The caveat is the engine position. The transmission position, driveshaft length and/or clutch linkage may need to be modified accordingly.
One things you may want to look at also if you are going from a 6cyl to an 8cyl is the radiator. The necks for the hoses are sometimes on the opposite sides. Also a 8 cyl capasity is larger .
37 chevy 1/2 ton
37 Chevy 1/2 Ton
86 Chevy Blazer
98 Drudge 24 valve Cummins
One worn out Timberjack
Junior Member
Junior Member
You will need to move the passenger side Motor mount.
I am not sure but the C10 might have bolt holes for the mount in the V-8 position.
My '66 C20 didnt have the mounts so i just welded the mount to the frame.
I put a pic of my motormounts on my website.
Mount Pic
1953 M38A1 (Military Jeep)
1962 K10
1963 FC170 (Ugly Jeep)
